help! car wont say running
Old 08-14-2003, 10:13 PM
thumpinTA's Avatar
help! car wont stay running
A few days ago my car overheated while driving. I pulled over and let it cool. I checked out my elec pump and it was working fine so i finished my ride home with no problems as far as temp but i noticed a few hesitations. I thought it was heat related. Later that day after the car was cold and sitting for a awhile i tried to start it but it would only run for about 5sec then die. Any ideas what would be causing this? Bad sensors? Anything i should check for? There are no engine lights on.
94 ta
elec. h20 pump
powerdyne 4psi
222/232
thumpinTA is offline
Old 08-14-2003, 10:28 PM
viperkiller's Avatar
this has nothing to do with heat but first thing is check for fire at the plug that gas
coilwire can do crazy stuff like that also
viperkiller is offline
Old 08-14-2003, 10:31 PM
Lyle A's Avatar
Possibly Ignition Module or Coil.
Lyle A is offline
Old 08-14-2003, 10:50 PM
thumpinTA's Avatar
thanks for the replies guys. Any ideas on how to check to see if the ignition module or coil is working properly. Anybody have any other ideas.
thanks,
Old 08-14-2003, 11:26 PM
Lyle A's Avatar
Scan or have it scanned for stored codes. That may help.
Lyle A is offline
cmdeshon
12-27-2014 10:06 AM
1996LT1Z28
12-04-2014 09:20 PM
nophix
11-30-2014 10:26 PM
USAirman93
11-24-2014 03:37 PM
supercharged94Z28
02-24-2003 10:22 PM
Quick Reply: help! car wont say running
