help! car wont stay running
A few days ago my car overheated while driving. I pulled over and let it cool. I checked out my elec pump and it was working fine so i finished my ride home with no problems as far as temp but i noticed a few hesitations. I thought it was heat related. Later that day after the car was cold and sitting for a awhile i tried to start it but it would only run for about 5sec then die. Any ideas what would be causing this? Bad sensors? Anything i should check for? There are no engine lights on.
94 ta elec. h20 pump powerdyne 4psi 222/232 |
this has nothing to do with heat but first thing is check for fire at the plug that gas
coilwire can do crazy stuff like that also |
Possibly Ignition Module or Coil.
thanks for the replies guys. Any ideas on how to check to see if the ignition module or coil is working properly. Anybody have any other ideas.
thanks, |
Scan or have it scanned for stored codes. That may help.
