Help car will start then cut off help!!!!!!!!
I thought it was the Icm put a brand new on today.The car ran about 5 min then cut off it will start then cut off .The opti is 6 mouths old it was put on at the dealership.I put a brand new accel coil on. what is could be the problem help please thanks.
So does the car actually start? Does it start, and then just die? Could be a vacum leak if that's the case.
The car will crank sometime and run good i put the icm on and it start up good sit there and ran for 5 min and cut off. every time i try to start it it run for sec and then cut off.
Sounds like the ignition module to me..it's located on the same bracket as the ignition coil.
done put a ICM on .
