HELP! Car running like crap after Headers and Cam
Old Aug 16, 2003 | 06:43 AM
  #16
Fast96WS6's Avatar
Re: Re: HELP! Car running like crap after Headers and Cam
Here's the deal. Installed my new programed OBDI PCM, and it starts running great. Then it starts running like crap again! as its warming up, I would hit the gar around 2K and the car would almost die. Then a few seconds later it LEAPED foward. Also when I come to a stop, the RMP's die down to about 500. This is the same problem I had before the programming, and now it seems worse. The odd part is that when I take it on the highway, it seems to run fine afterward, but the idle problem is still there.
THIS IS DRIVING ME NUTS. At one point it seemed to misfire when I started going from a stop sign, but not at higher rpm's. I'm also throwing a code with the new PCM. I'm going to buy the cable and scan it.
One more thing that I think could be an issue. Cyl # 5 wire kept getting burnt, so I ran a cyl # 8 wire to it becasue it was longer and ran it over the header instead of under. Could this longer wire be a problem?
Does anyone know what the problem is. I need help ASAP
Originally posted by anasazi
bing bing bing we have a winnahr!!!
What do you mean by this. The new O2's and FF are bad?
Old Aug 16, 2003 | 08:07 AM
  #17
Fast96WS6's Avatar
I just found this searching for info about the TPS....
http://autos.groups.yahoo.com/group/...la/message/564
A guy with an Impala SS seemed to have a similar problem. He had to switch his MAF sensor and it cleared up. Could this be the problem?
Old Aug 16, 2003 | 10:53 AM
  #18
Fast96WS6's Avatar
TTT
Old Aug 16, 2003 | 11:40 AM
  #19
besz28's Avatar
coil
Old Aug 16, 2003 | 01:05 PM
  #20
Fast96WS6's Avatar
Originally posted by besz28
coil
I actually just ordered a coil. Why do you think that?
Old Aug 16, 2003 | 01:26 PM
  #21
besz28's Avatar
the way you said it dips down to 500 mine did that and it was a coil.
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
ro2207
Dec 4, 2014 06:18 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
