Fast Track harness install question
Old Aug 16, 2003 | 01:51 PM
Jesse_Boyer's Avatar
I need a little help decifering what this means in the directions.
It says "splice orange wire tagged 12 BATT from FRELPRO PCM connector cavity M-01 into orange wire that terminates at GM PCM connector B cavity 15 or cavity 30"
It also says "this is a 3-way splice."
For reference, there are 5 steps that have 3-way splices. The next connection is "Splice pink wire tagged KEYPOWER from FELPRO PCM connector cavity L-03 into pink wire that terminates at GM PCM connector B cavity 30."
So, tell me what to do? what is the "3-way" splice? Since these are the power circuit connectors, should I just "slide" the insulation away from the existing wire and make the splice, leaving the wire connected to BOTH pcm's? or should I simply cut the wire from the stock PCM and connect it to the speed pro?
Jesse
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Dec 8, 2014 08:01 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
