help car dies when idling
Old Nov 10, 2007 | 03:20 PM
camaro79323's Avatar
my friends 95 z28 car dies when it is just idling. after it dies it starts right up no problem no miss or anything. the car runs fine then when he stops at a light or drive thru it dies so any help would be nice. tia
Old Nov 10, 2007 | 04:33 PM
hektyk's Avatar
No check engine light? Have you checked the plugs and fuel filter?
Old Nov 10, 2007 | 04:40 PM
mrmint69's Avatar
How many times has it done it. How long was the car running for also?
Old Nov 10, 2007 | 08:44 PM
no ses light or anything and it starts right up afterwards and runs just fine
Old Nov 10, 2007 | 09:32 PM
GOFASTER's Avatar
Is it an A4? Could the torque converter not be unlocking?
Old Nov 11, 2007 | 08:44 AM
yea its an auto its has shorty headers,cold air and stall
Old Nov 11, 2007 | 08:46 AM
guess the car was running for about 30 minutes or so when it did it then ran fine for along while when it did it again.
Old Nov 11, 2007 | 10:26 AM
LexLT1-Z28's Avatar
Having similar problems, stock 95Z A4 of my stepsons.. Won't idle, won't move with out poping etc. Not safe to drive. No oil or water leaks onto opti. Everything looks perfect. Just came out of the blue with no codes.
Old Nov 11, 2007 | 11:36 AM
the car is running fine it just randomly does this every now and then.
tia guys
Old Nov 12, 2007 | 09:48 PM
anyone else????
Old Nov 13, 2007 | 08:30 AM
9formula4's Avatar
mine was doing the same thing right before I parked it for the winter to rebuild it. I will follow this thread to see the outcome.
Old Nov 13, 2007 | 04:49 PM
steve40's Avatar
we had a car do something really similar...ended up being the fuel pump...the car would prime the pump, start and die, had to put a gauge on the fuel rail and have someone watch that it didn't make enough pressure to keep the motor going.
Old Nov 13, 2007 | 10:37 PM
Wild1's Avatar
It could be a number of things but since you mentioned that it happens at stop lights. If that is true, perhaps the lock up on the torque converter is not releasing. Fluid change may help if it is sticking. More severe mechanical issues with the lock up on the torque converter could be a bit more costly.
bfmv13trivium
Jan 14, 2015 09:57 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
