HELP! Car dies???????
Old Nov 9, 2008 | 04:04 PM
e-rocker's Avatar
Unhappy HELP! Car dies???????
OK, here's the problem. First let me just say that the 93 LT1 opti-spark was replaced about 15K miles ago, it has 125K on the motor, basically stock. Drives fine, but ignition system shuts down on me after 10-20 mins on the highway. 2200 rpm. Could it be...?
A) The ignition module is failing.
B) The Coil is going bad.
C) Bad opti-spark
D) Someone mentioned something about the fuel pump could be bad?
Please any feedback would help.
Thanks a lot.
Eric
Old Nov 9, 2008 | 04:47 PM
Have you scanned if for codes? Since you have a 93, all you have to do is short the ALDL pins and flash the codes on the SES light. Courtesy of Shoebox:
http://shbox.com/1/dlc2.jpg
Then check the codes on Shoebox's code list, being careful to use the column on the far right, which has the codes that are specific to the 1993.
http://shbox.com/1/Dtcs.htm
No codes for the fuel pump, but that's simply a matter of checking the fuel pressure.
bfmv13trivium
Jan 14, 2015 09:57 AM
ModdedNerd
Dec 18, 2014 10:52 PM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
