Help Broke the end of my Low oil sensor
Old Apr 12, 2008 | 03:29 PM
a4z28's Avatar
Well today i was taking out the low oil sensor to fix a leak and i some how broke the end of the sensor the clip that holds the wiggly piece fell in not the wiggly piece itself is this a problem or what. Thanks
Old Apr 12, 2008 | 06:17 PM
maverickmk's Avatar
if you left any parts inside the pan the pump will most likely suck them up and cause a problem
Old Apr 12, 2008 | 07:30 PM
Pontiac_97's Avatar
depends on how big the parts are that fell in. there is a screen on the oil pump pickup tube that would prevent big things getting sucked up into the pump
Old Apr 12, 2008 | 11:05 PM
a4z28's Avatar
anyone else?
Old Apr 12, 2008 | 11:12 PM
Stl94LT1's Avatar
I broke the floater off my oil level sensor, and didn't even know it had one. Put a new sensor on the car and drove it for two years. Pulled the pan for a bad gasket. The floater piece had been chewed up into small pieces, many of which were stock to the oil pump screen. Cleaned up everything I could find and put the car back together. That was four years ago and it's still running strong.
Old Apr 12, 2008 | 11:13 PM
Dave1980's Avatar
is the clip ferrous? (magnetizable)
Old Apr 12, 2008 | 11:15 PM
caldercay's Avatar
If anything larger than warn metal particles (ferrous or not)
falls off into the pan, I'd yank it and get it out of there.
HectorM52
Jul 30, 2017 11:46 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
