Help with AFR rev kit!
Old Jul 3, 2003 | 09:22 PM
bunker's Avatar
Ok I just baught a kit off a board member, I called AFR & they said I need the 6155 kit which is for stock lifters even if I have comp R lifters since its for stock style lifters. But just before I called them I emailed them aswell, now I got an email from them that I need the 6150 kit for my COmp R's cuz they are aftermarket lifters, but on the phone they told me thats for retro style etc...
If anyone knows whats going on LMK, otherwise I just baught the wrong kit
Thanx.
Old Jul 3, 2003 | 10:27 PM
bunker's Avatar
TTT
Old Jul 3, 2003 | 10:37 PM
93formula's Avatar
tech guys are so fuggin stupid. im sure someone here has them on there car and would know which one youd need, maybe there both the same
Old Jul 3, 2003 | 11:25 PM
turbo_Z's Avatar
why do you think you need the REV kit? are you getting valve float? did you install the wrong valvesprings? i thought the comp R lifters have same body as the OEM but with stiffer springs to withstand high lift cams... never seen one however.
Old Jul 4, 2003 | 12:17 AM
bunker's Avatar
Well I have an XE cam 236/242, at high RPM it could get a little messy so its nice to install a hydra rev kit, I got a pretty good deal for it so I went ahead with it considering my car is on jackstands with no cam right now, I figured might aswell I did a search & I think you have to use the 6155 on Comp R's basicly same one you use with factory lifters, I think the tech guys are just stupid, considering the body looks identical.
Old Jul 4, 2003 | 12:19 AM
93formula's Avatar
if it fits use it
Old Jul 4, 2003 | 02:02 AM
bunker's Avatar
Shut up Roy! thats the stupidest answer yet I know it'll fit, I just want to konw if its the right one, prolly is, just want to know.
Old Jul 4, 2003 | 07:05 AM
RUFFIDLNZ's Avatar
I would like to know as well. I have heard both answers as well so could someone please get an answer on this?
Old Jul 4, 2003 | 10:24 AM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
I think you'll have to use the 6150 kit. The bodies are the same between the stock and comp R's, but I think the top surface is different. I know when I say Jordon's kit on a Turbo'd 383, his used some black alignment keys - and he has Comp R's for lifters. I'm using stock lifters w/ the factory alignment keys and 16 little "nubs" that rest on top of the lifter body.
But, I have some comp R's on order as this HE grind cam is floating my valves at about 6k. <- It's the only thing I have left to change! LOL.
Old Jul 4, 2003 | 10:31 AM
CSJTA's Avatar
The Comp R's and the Stock Lifters are the same "Style" lifter, so you got the right Rev Kit, or the 6155 Kit.
Old Jul 4, 2003 | 10:46 AM
bunker's Avatar
Ok good, so 100% 6155 then?
I hope you see what I mean guys, I hear different opinions.
Old Jul 4, 2003 | 11:07 AM
Bunker, the 6150 is the right kit... The top mount area where the spring cup would go IS *supposed to be* DIFFERENT than a stock style lifter. I just called and made sure I was giving you the correct info .
Err hell.. you have both lifters still right? The stock & comp R's? You can check out the tops and see what I mean. <-- Assuming Jordache is right.
Old Jul 4, 2003 | 11:25 AM
bunker's Avatar
man what??? this sucks
does anyone use the 6155 with Comp R's?
Old Jul 4, 2003 | 11:46 AM
Go to their website and you'll see.. Well, they have two pics of their rev kits.. The top pic is what I remember seeing on Jordon's. <- again, he has comp R's.. Mine, OTOH, uses stock lifters and I'm running the kit that's in the 2nd pic. Uses the individual spring cups.
Old Jul 5, 2003 | 02:50 AM
97 WS6 T/A Conv's Avatar
Shawn,
The top pic is the kit he just purchased. I sold it to him. I was using that kit with the stock lifters too. Both of us verified he was getting the correct kit as both of us contacted AFR. As I understood it, the second style kit (bottom pic) is actually for lifters that have the "arms" connecting a pair of lifters, which makes sense since the attaching arm would hit the raised body on the lifter guides in the top picture. . The top kit (the one he purchased from me) is used for the individual lifters.
I think you will be okay with the kit you have (on the way) bunker.
