Help: ABS light, airbag light, and Code 43 on 94 Z28
Old May 31, 2004 | 08:21 PM
zmanlt1's Avatar
Hey guys, I just put a set of MAC Headers, removed AIR pump, Converted to electric waterpump, and rebuilt the tranny. As soon as I started my car, Service light came on along with ABS INOP light and airbag light. I thought the service light was the airpump until I got it tuned out of the PCM by PCMFORLESS. That is when he told me my car has code 43 which is Knock sensor circuit and the car is losing 9 degrees of timing. What could be causing all this? Has this happened to anyone else? Any help is appreciated. Thanks, Tom.
Old May 31, 2004 | 09:05 PM
DTC 43 sets when the PCM doesn't "see" the knock sensor. When that happens, the PCM defaults to an algorithm that pulls timing under virtually ALL circumstances.... up to 15-degrees.
Either the KS is bad, the harness wire is bad or the connector is off the sensor.
Old May 31, 2004 | 09:27 PM
Lyle A's Avatar
The ABS inop could be due to the lamps in the third brake light being out. For the air bag, start with checking the fuse (#1) in the IP fuse panel on the end of your dash.
Old Jun 1, 2004 | 03:54 PM
zmanlt1's Avatar
The third brake light works fine, and the #1 fuse is good also. What else could it be?
Old Jun 2, 2004 | 12:00 AM
OBE1 95Z28's Avatar
The ABS and Air Bag get their ground from the ground post located on the passenger side fender, next to the red plastic positive terminal. This ground is famous for getting dirty and causing a "light show". Disconnect the negative on your battery, remove the wires from your ground terminal, remove the ground stud and scrap away the paint from under the ground stud. Clean the ground stud and reassemble.
Old Jun 2, 2004 | 12:21 AM
Brent94Z's Avatar
Super Moderator
You installed headers... make sure your knock sensor wire didn't get melted
Old Jun 2, 2004 | 04:10 PM
zmanlt1's Avatar
I'm gonna check that out now. I'll let you know. Thanks
Old Jun 2, 2004 | 04:14 PM
zmanlt1's Avatar
I checked the wires for the knock sensor. They were close but the insulation was not melted. I put the stock knock module and that didn't fix it either. I think i'm just gonna replace the knock sensor and see what happens. Thanks, Tom
Old Jun 2, 2004 | 11:03 PM
zmanlt1's Avatar
OBE1 95Z28 : Thanks for the info, your advise fixed my ABS and Airbag lights. Thanks, Tom
Old Jun 3, 2004 | 12:14 PM
Its EXTREMELY easy to check the KS and the wiring. Pull the connector off the KS, key "on" and probe from the harness connector pin to the block. Should be +5V. If it isn't you have a wiring problem. Then with the connector still off the KS, probe from the single pin on the KS to the block. Should read 4,500 ohms, +/- 1,000ohm. If it isn't the KS is bad or the ground it bad.
Put the connector back on the KS. Probe from the wire to the block, should read 2.5V.
Or you could use the Mr. Goodwrench approach of "let's try replacing parts until we find the one that was bad."
Old Jun 3, 2004 | 06:15 PM
OBE1 95Z28's Avatar
zmanlt1,
Glad the ground fixed part of your issues! That's the power of this board, sharing info!
Gtpguy
Jan 26, 2015 04:50 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
