HELP! ? about welding relocation brackets
Old Aug 31, 2003 | 02:29 PM
PatriotTA's Avatar
Exclamation HELP! ? about welding relocation brackets
I am in the middle of welding in the BMR weld-in relocation brackets. I took off my old LCA, and I have a new BMR tubular LCA in its place. When I go to line up the bracket, there is about a 1/2" gap between the back (top) of bracket and the original bracket. The car is in the air, but the suspension is fully loaded. The rear end is jacked up so that the full vehical weight is on the rear suspension. Has this happen to anyone else? I don't want to modify the bracket if I don't need to. What should I do?? I was considering modifying the top hole in the relocation bracket, so it is elongated. This will allow me to move the bracket up so that the back (top) side of the bracket will contact the stock bracket on the rear end. Would this be an acceptable option?
Old Aug 31, 2003 | 03:37 PM
Transamdriver's Avatar
By my BMR instructions sitting beside me the rear only needs to be supported and not under load. The car should be supported by the frame.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
War Engine
Sep 18, 2015 07:28 PM
Boss002
Jul 24, 2015 10:47 AM
