Help!!!
Old Nov 15, 2011 | 05:50 PM
Toukijin's Avatar
Help!!!
I have a 1994 T/A stock yesterday after work I got in it and started it.....I turn the key and it cranks and cranks,but doesn't start,any ideas?
Old Nov 15, 2011 | 06:36 PM
jcl69cam's Avatar
Re: Help!!!
Can you hear your fuel pump when you turn the key to start. If not, there is your answer. If you can hear it, try to get a fuel pressure reading. Could also be a spark issue.
Old Nov 15, 2011 | 06:37 PM
Re: Help!!!
Check basics-spark and fuel pressure (with a gauge).
Old Nov 15, 2011 | 10:37 PM
Toukijin's Avatar
Re: Help!!!
Jcl69cam: I can hear the fuel pump prime.Thank You for your response.
Shoebox: What ways can I got about checking for a spark?. Any help I will greatly appreciate.
Old Nov 16, 2011 | 06:30 AM
Re: Help!!!
Basic stuff. Pull a plug wire and hold it where the metal contact is close to a good ground and see if it has a good, blue arc when cranking. Use some insulated wire pliers if you are concerned about getting shocked (hold by the insulation or boot-not by the metal part). A spark plug with it's body grounded can also be used. The coil wire can be checked in a similar manner, but you won't be able to attach a spark plug on the opti end of the coil wire.
Old Nov 16, 2011 | 11:10 PM
Toukijin's Avatar
Re: Help!!!
Thank You I'll try that.
Old Nov 17, 2011 | 12:26 AM
kwik_ta's Avatar
Re: Help!!!
How was the car running before this happened? Is or has the ses light been on? Is be more inclined to think cam or crank sensor if you have fuel... But that's if tested for pressure at the port.
Old Nov 17, 2011 | 05:22 AM
Re: Help!!!
No crank position sensor on his 95. The cam position sensor is the optical module in the Optispark distributor. If it fails, it will set one or two codes (DTC 16 and DTC 36), but neither of those codes will turn on the SES light. DTC 16 prevents the engine from starting by shutting down the fuel system - pump and injectors.
Old Nov 18, 2011 | 12:05 AM
Toukijin's Avatar
Re: Help!!!
The car was running fine. Hopped in it started up and drove it to work with no problem. When I got off of work to drive home it would not start,it would crank hard,but it wouldn't and hasn't started since (will still crank).
Pulled the spark plug and I dont see a spark.....so what do I do now?...new Opti?
Old Nov 18, 2011 | 06:47 AM
Re: Help!!!
Did you also check the coil wire? Have you ever checked for any trouble codes? Read the opti diagnosis sticky at the top of the forum before replacing the opti.
Old Nov 20, 2011 | 12:47 AM
Toukijin's Avatar
Re: Help!!!
No I haven't checked for any trouble codes. I need a scanner for that right?. Is it possible to rent one? I did not check the coil wire I'll do that int he morning....
Old Nov 20, 2011 | 08:37 AM
Re: Help!!!
You need an OBD-I scanner, and not one of the $30 cheapies that simply shorts the pins in the ALDL connector. That won't work after 1993.
You can also get a cable for a laptop and free scanning software:
http://www.akmcables.com/
http://www.andywhittaker.com/ECU/Fre...0/Default.aspx
DataMaster is free download, and 20 free uses. Then you have to buy it.
http://www.ttspowersystems.com/DataMaster.html
