helo with oil pressure
Old Apr 19, 2005 | 08:36 PM
Inutero's Avatar
Well I replaced this piece http://shbox.com/ci/oil_pump_drive.jpg
Now the oil pressure guage is absolutely pegged the farthest it will go (past 80 psi). It doesn't even flucuate, it just stays pegged.
Anyone have an idea on what is wrong?
Old Apr 19, 2005 | 08:57 PM
Robs97Z28's Avatar
Re: helo with oil pressure
can you put on a mech oil gauge to double check the oil pressure?
Old Apr 19, 2005 | 09:03 PM
Dave89IROC's Avatar
sounds like you either pinched the wire to the oil pressure sensor or unplugged it
Old Apr 19, 2005 | 09:06 PM
1racerdude's Avatar
Your guage,wiring or something is grounded,ahead of the sender. Your guage is obviously good or it would not peg.
Unhook your sender,if the guage comes back down there is something going on with the new sender.If it stays pegged there is either the wire or the sender side of the guage is grounded.
Old Apr 19, 2005 | 09:15 PM
Actually it's the opposite on the 4th gen. If the sensor is unplugged or wire broken, the gauge will peg. If it is grounded, the gauge will read zero.
You probably knocked the wire off to the sensor when you were doing your recent work.
Old Apr 19, 2005 | 09:21 PM
1racerdude's Avatar
I stand corrected.
Old Apr 19, 2005 | 09:28 PM
kainZ's Avatar
Mine's doing the exact same thing, but only when I rev it up. At first it wasn't coming back, but now it goes right back down after I let off the gas....
Old Apr 19, 2005 | 09:31 PM
1racerdude's Avatar
Better check your's with a manual guage to see IF you have low pressure.
Old Apr 19, 2005 | 09:44 PM
Originally Posted by 1racerdude
I stand corrected.
What you said is the way the gauge always worked on the the older GMs I have worked on. For some reason, it's not that way on our cars.
Old Apr 19, 2005 | 09:57 PM
kainZ's Avatar
But it seems like I have pressure.. because the gauge reads / functions normally all the time besides when it is at 90psi.. when its not at 90, its doing all the normal things it did before.. dropping down a bit when the car has been idling for a while, creeping up slowly as I slowly increase engine rpm, etc. Do you really think I could have low pressure?
Old Apr 19, 2005 | 10:47 PM
1racerdude's Avatar
YES,or thin oil.
Old Apr 19, 2005 | 11:36 PM
kainZ's Avatar
Just changed oil... 5 quarts of Mobil 1 10w30 and a new K&N Filter..
Old Apr 20, 2005 | 12:12 AM
1racerdude's Avatar
Is it a stock engine or built? How many miles if stock? If built what are the brg clearances?
Old Apr 20, 2005 | 01:06 AM
kainZ's Avatar
Stock bottom end, 107.5kmiles, brand new built heads and new pushrods, roller rockers, etc.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
