Hello! Just replaced the coolant temp sensor on the head; gauge wont move! :(
Old Sep 29, 2005 | 11:51 PM
Black1995Z's Avatar
Arrow Hello! Just replaced the coolant temp sensor on the head; gauge wont move! :(
Well, I broke my temp sensor and had it rigged for a few months. It worked but the plug fell off of the sensor occasionally so I replaced it.
Now my gauge doesnt read over 100 , which is as low as it could read. Has anyone had this problem before? I thought a long time ago I saw a thread about this same problem.. I tried a search but couldnt find it.
Any suggestions?
The sensor fit well on the head and looked great and the plug fit the sensor well too.
Old Sep 30, 2005 | 02:52 AM
SS RRR's Avatar
Re: Hello! Just replaced the coolant temp sensor on the head; gauge wont move! :(
Where did you get the sensor? It's possibly the wrong one. The PCM water temp and guage temp sensor are different part numbers. I once tried to get the PCM sensor from a parts store, but it was the wrong one and ended up going to the dealer to get the correct one.
Old Sep 30, 2005 | 04:38 AM
smoknta's Avatar
To test your guage you can supply 12 volts on the connector and the guage should peg.
Old Sep 30, 2005 | 05:07 AM
Dave89IROC's Avatar
no!!, you ground the gauge, ground is pegged one way and unplugged the other
Old Sep 30, 2005 | 08:20 AM
smoknta's Avatar
By bad...I could have sworn it was applying 12 volts.
Old Sep 30, 2005 | 08:48 AM
Definitely not.
Old Sep 30, 2005 | 11:29 AM
Black1995Z's Avatar
I'll see if I can find the box for the p/n.
Would thermal paste help for a solid connection?
edit/update: Tested it and it works, thermal paste didnt help though. I was unable to locate the box, but I'm pretty sure it was a borg warner. Any other ideas?
Old Sep 30, 2005 | 02:54 PM
What was it you tested, the wire and gauge or the sensor?
Testing info
HectorM52
Jul 30, 2017 11:46 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
brentbrowning01
Dec 16, 2014 06:35 AM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
