Heater valve
Old Nov 9, 2003 | 02:00 AM
ZyberMunster's Avatar
Heater valve
Can anyone tell me where the A/C heater valve is on a 94Z?? is it electrically or vacuum actuated??
Thanks!!
Old Nov 9, 2003 | 04:22 AM
bunker's Avatar
both, vacume to open to door to suck cold air & electronically to turn on the AC condenser.
Old Nov 9, 2003 | 12:44 PM
The only real "valve" is the door that causes air to pass through or bypass the heater core. It is controlled by a cable that is attached to the temp dial on the dash. The door is inside the HVAC housing. The other doors that route air to different locations are vacuum controlled.
Old Nov 9, 2003 | 01:03 PM
Thumbs up
Thanks a bunch, guys!! I'll check it out and keep you posted.
Thanks again!!
Old Nov 14, 2003 | 04:07 PM
Thumbs up
Fixed!! Pulled the lower passenger side panel off, about right in the middle there is a "pulley" that connects with to the cable from the HVAC "temp" ****. Apparently, after 104K miles it was kinda loose allowing the heater "valve" door to stay open in the heat mode. Tightened/adjusted and ...COLD A/C AGAIN!!!
Thank yous to all that responded!!!
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
350350
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
