heater hose question....
Old Jul 21, 2010 | 10:55 PM
Eric85's Avatar
Im taking the heater hoses off my the LT1 in my s10 and was curious if i need to connect the 2 fittings on the water pump or if i could just put a rubber cap on each fitting.
Old Jul 21, 2010 | 11:00 PM
Ricardo's Avatar
Put a rubber cap on each fitting.
Old Jul 22, 2010 | 05:22 AM
The LT1 cooling system is designed to provide a constant flow through the heater loop, whether the heater is being used or not. The flow restrictor in the hose controls how much flows.
Old Jul 22, 2010 | 02:54 PM
Eric85's Avatar
So what should i do with them? Im kinda confused on what your saying here.
Old Jul 22, 2010 | 02:59 PM
I've seen people cap them or loop them. I don't know that anyone has had any real trouble either way.
Old Jul 22, 2010 | 03:38 PM
Eric85's Avatar
awesome thats all i needed to know
thanks guys!
Old Jul 22, 2010 | 04:54 PM
I have the original SAE paper on the LT1's reverse flow cooling system design. Something tells me they put that constant flow there for a reason, but its probably 5 years since reread the paper.
Old Jul 22, 2010 | 09:39 PM
Eric85's Avatar
well i put it to you this way. My s10 doesnt have any special heater hoses on it so i dont think its doing anything.
Old Jul 23, 2010 | 07:30 AM
blackbirdta's Avatar
why ask then?
I bought a 92 corvette pump so I would have less inlets/outlets to worry about. It only has one port so it wouldn't be possible to loop anything in my case it doesn't seem like. So I was going to cap off since I have no hoses to loop. I'm not sure how that would effect the cooling yet.
Old Aug 15, 2010 | 11:18 PM
Eric85's Avatar
hate to bring this back up but ive never taken heater hoses off before am i going to have a huge mess to clean up from antifreeze and such?
Old Aug 15, 2010 | 11:25 PM
Mswezey's Avatar
From: Wichita Falls, Texas - College. DF-Dub, when not in college
yes....if you're not careful about it.
makes sure you let the car cool down though!
Old Aug 16, 2010 | 09:46 AM
95z28onjuice's Avatar
loosen the petcock on the radiator and let it drain for a while then remove the hoses at the pump with a catch can under it. that should help control the major mess area.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
