Which of these would go with pacesetter headers ?
Old Aug 15, 2010 | 06:11 PM
TheBlur's Avatar
http://www.jegs.com/webapp/wcs/store...Id=10002&Nty=0
The ones on now are 10mm wrench head 1.5 pitch bolts. I wish they had something where I could utilize allen head wrenches....
Old Aug 15, 2010 | 06:41 PM
brucer's Avatar
go to your local fastener supply place and they can get you some...
are you wanting header bolts? header bolts should be 3/8-16 bolts.
Old Aug 15, 2010 | 08:29 PM
RamAir95TA's Avatar
Get a 1" stainless ARP 12-point 5/16" head size bolt from Summit for $22.
Old Aug 15, 2010 | 09:40 PM
lt1-xjs's Avatar
The Mr, Gasket 916 are allen heads, you may just need 2 packs. As stated 3/8-16 x 3/4 should be the correct size and could likely be found at Lowes. A supply house such as Fastenal should have them. You should ask for a 3/8-16 x 3/4 SHCS ( socket head cap screw ).
Old Aug 16, 2010 | 09:49 AM
95z28onjuice's Avatar
Any standard sbc header bolt should work
mrwz28
Jul 8, 2015 09:11 PM
Koby
Jun 28, 2015 04:46 PM
drptop70ss
May 4, 2015 08:22 PM
