heater core
Old Sep 18, 2004 | 06:27 PM
WheelsupChad's Avatar
heater core
got a 96 looks like maybe the heater core might be leaking right at the fire wall car got hot anyone change them out do you get it out from the inside looks like it might be a job?....do the fans run when you kill the car thought about just making them come on when the motor is running hook them up derect?
Old Sep 18, 2004 | 07:24 PM
S8ER95Z's Avatar
Re: heater core
Its not really too hard..just did it this morning. ~5 little bolts holding the heater box together.. I took off my glove box (3 bolts) and pulled the panel out. Then took off the hoses from the outside (1 more bolt under the hood) and it pulls right thru from the inside. Angle is down and pull it out. I did it in ~30mins (wasnt timing or anything..just figure an hours time) New one was ~50 bux at autozone.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
ducttape1975
Jul 10, 2015 06:29 PM
