Heat soaked starter from LTs?
Old Feb 22, 2004 | 02:46 PM
PatriotTA's Avatar
OK, I am getting together a parts list for my header install, and the last thing I'm debating is whether or not to get a starter blanket. I ordered a set of Hooker LTs (ceramic coated), and I'm not sure if the starter is going to experience heat soak problems. Has anyone here had problems with their starters after an LT install?
Old Feb 22, 2004 | 02:50 PM
Spinner's Avatar
No issues here, the LTs are farther away from the starter then the stock Y-pipe was.
Old Feb 22, 2004 | 02:55 PM
joeSS97's Avatar
No problem here either.
Old Feb 22, 2004 | 02:57 PM
12SCNDZ's Avatar
My MAC y-pipe is about 1/16" away from my CVR starter. Admittadely, my starter is mounted upside down to clear everything...It's 8 way adjustable. So far, I've had no problems with hot starting.
Frank
Old Feb 22, 2004 | 03:31 PM
Ricardo's Avatar
No problem here either. There is about 1 1/2" clearence between the fron of the starter solenoid and the LT´s . Have my Hookers for abot two years now.
Old Feb 22, 2004 | 03:40 PM
ibanez6rg's Avatar
I had no problems for 5 or so months that my car was running. On C4s, the exhaust is right by the starter, so I don't think its anything to worry about.
Old Feb 22, 2004 | 04:08 PM
Rodrigues's Avatar
My starter cracked into two pieces with long tubes, then I got the LT4 starter and no problems since.
Formula Steve
Sep 19, 2023 08:31 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
CARiD
Sep 30, 2015 05:44 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
damnyankee36
Sep 9, 2015 07:06 PM
