Heaglight motor wont turn off
Old Jun 5, 2003 | 10:22 AM
93transam1234's Avatar
Unhappy Heaglight motor wont turn off
ok this just happend out of no where,
I went to the store lastnight and when i turned the headlights off the they both closed but the motor one the right one kept on trying to turn and made a loud noise for like 5 sec then finally turned off. and it keeps doing it now when ever i turn the lights off...PLEASE HELP
Old Jun 5, 2003 | 11:13 AM
moparman's Avatar
The gear is worn on one side. Do a search for "headlight fix".
Old Jun 5, 2003 | 11:17 AM
u sure?
that will make the motot stay on evern after the headlight is all the weay down?
Old Jun 5, 2003 | 11:35 AM
N2OpwrdTA's Avatar
Your little gear in there the flips the light up souds like its stripped. Do a seach on the net...youll find cheap fixes for it. One thing i remember reading was to take the motor/headlight apart and find the little gear that moves the light. Then flip it 180degrees and reinstall it. Apparently this works becasue the motor only uses half the gear to turn the light up and down...so the one side of the gear is never used. Could also, just replace the gear if you wanted. Otherwise, youll have to spend about $250 on a new headlight motor. Good luck.
Old Jun 5, 2003 | 12:19 PM
magius231's Avatar
http://www.bfranker.badz28.com/headlightfix/index.htm
Old Jun 5, 2003 | 12:24 PM
Formula_one's Avatar
I had the same problem. It was the gear inside the motor. I bought a pair of brass gears and put one in each motor and havent had any problems since.
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
formula79
26
Aug 5, 2002 12:21 PM
