Which heads should I use?
Old Dec 1, 2006 | 10:40 AM
davidarel's Avatar
I have been looking at the AFR 195cc but have seen so many alternatives out there. I have a stock bottom end 95 LT1 with many upgrades to the top end (except for the heads) and I am now at the point where the heads are blocking more power. I am curious as to what you guys are using and how you like the product.
Old Dec 1, 2006 | 11:13 AM
calfirebird's Avatar
If it was me personaly i would drop the afr idea and go with tfs ported by a good porter. Afrs require that you run a Lt4 intake so add about another 450 if you get an eldelbrock intake. I would stick with the Lt1 side and make just as much.
Old Dec 1, 2006 | 02:54 PM
2000GTP's Avatar
Have you considered sending your stock castings to a reputable porter like Lloyd Elliot or Advanced Induction?
Old Dec 1, 2006 | 04:05 PM
526 SS 96's Avatar
I had good results with porting my stock heads (see sig). It will be less expensive than buying new castings and then having them gone through.
Old Dec 1, 2006 | 04:10 PM
WS Sick's Avatar
If youre sticking with a 350 I would stick with the stock castings ported.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
