heads the same?
Old Jul 25, 2007 | 12:55 AM
sn8ke eatr's Avatar
heads the same?
i have a 1993 camaro and the motor will be pulled in the next few months.
i believe i have iron heads,correct?,
i came across a set of aluminum lt1 heads from a 1996 engine. are these heads exactly interchangable or are any bolts or holes in different places?can i use these instead when my engine is rea-assembled?
also, what kind of weight savings would aluminum heads offer over my stock iron ones?
thanks for any help in advance
Old Jul 25, 2007 | 01:07 AM
Stl94LT1's Avatar
Nope, you've got aluminum heads.
Old Jul 25, 2007 | 08:17 AM
Javier97Z28's Avatar
Moderator
All F-body LT1's came with aluminum heads...
Unless someone swapped in a Caprice/Impala/Roadmaster/Fleetwood LT1 somewhere down the line in your car's life.
Old Jul 25, 2007 | 09:16 PM
red67camaro's Avatar
An easy way to test if your heads are iron or aluminum is to use a magnet.
If the magnet "sticks" they're iron. If it doesn't, they're aluminum.
Old Jul 26, 2007 | 07:03 AM
sssalah's Avatar
The aluminium and iron LT1 will interchange without a problem. The weight is roughly 40 lb for iron and 20 lb for aluminium per head.
Old Jul 26, 2007 | 07:52 PM
sn8ke eatr's Avatar
oh ok great, thanks guys
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
