Heads put on wrong side????
Old Sep 8, 2004 | 04:12 AM
cmking26's Avatar
My machinist put my heads on the block but put them on the wrong sides. ie driver side head on passenger side vice versa. Is this ok? Now the holes I need for coolant crossover and coolant sensor are plugged up. Can I just swap these plugs and everything be ok?
Old Sep 8, 2004 | 05:07 AM
missetti's Avatar
Re: Heads put on wrong side????
Yes, just pull the plugs and reinstall them.
Old Sep 8, 2004 | 06:06 AM
30696bird's Avatar
there are plugs on both sides of your heads........take the plugs out of the back side reinstall on front side. No big deal unless you're like me, I had no plugs in the front (machine shop) and filled it up with water. Can you guess where all that water went??? That's right coil and opti it dried out out and was no big deal, except pulling all the crap off the front of the engine to put the plugs back in!
Old Sep 8, 2004 | 09:11 AM
WS Sick's Avatar
They may be frozen so prepare for that, some light heat (not excessive) will assist in loosening them. Heat only on the plg, not the surrounding alum.
Old Sep 8, 2004 | 02:18 PM
Mtrhds94Z's Avatar
The heads are the same/reversible..
Check the coolant temp gage sender hole also.. probably now the opening is in the right rear side instead of the driver's front..
Old Sep 8, 2004 | 02:31 PM
cmking26's Avatar
Thanks for all the replies. I already swapped out coolant crossover plugs now I just need to get coolant sensor plug out.
Old Sep 8, 2004 | 05:41 PM
1 Nasty Bird's Avatar
wouldnt that put the EGR up front? Unless your plugging it that would be a problem. and are their the same accesory mounting holes on the back of the heads too?
Old Sep 8, 2004 | 06:19 PM
Loadre's Avatar
The EGR is on the back of the Intake Manifold.
Old Sep 8, 2004 | 06:39 PM
brain fart, time for more mountain dew and red bull.
Old Sep 9, 2004 | 02:22 PM
Mtrhds94Z's Avatar
Mounting holes are on both ends also..
Old Sep 9, 2004 | 02:54 PM
WS Sick's Avatar
Unless its a Ford....lol
MadMav
Feb 6, 2015 11:02 PM
InfernalVortex
Jan 17, 2015 09:35 AM
NewsBot
Dec 28, 2014 06:20 PM
Queens94z28
Nov 20, 2014 06:03 PM
