Heads gasket
Old Apr 29, 2003 | 01:39 PM
scyzoryk's Avatar
Heads gasket
Which one to pick and where to buy it cheap ?
Old Apr 29, 2003 | 07:54 PM
EvlViln's Avatar
Felpro #1074, its .039, which will give you more compression and better cooling. You will probably spend about 35 each. You have to pay to play.
Just for reference, the Impala SS 94-96 head gasket is .029, but it has worse cooling capabilities. I would, and have bought the felpro time and time again.
Old Apr 29, 2003 | 09:11 PM
94F1Z28's Avatar
I was planning on using the impala head gaskets and was wondering what you mean by worse cooling capabilities?
Old Apr 30, 2003 | 02:54 AM
EvlViln's Avatar
The Felpro has larger holes in it to allow more coolant to flow throught the head, the Impala Gasket (remember the Impalas had iron heads, so they cool differently) has really small very restrictive holes for the coolant, this means that the Impala head gasket, while having a much better thickness than the Felpro, will make you heads run hotter, promoting detination and making the Knock sensor dial back the timing (i.e less power). I say Go Felpro, but its you money, do what you feel is best.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
