Head's Finally Showed up...
Old Jan 23, 2006 | 06:46 AM
IllusionalTA's Avatar
Waited for 2 month's or so.. But it was well worth the wait IMO.. let the fun begin...
Old Jan 23, 2006 | 08:31 AM
RealQuick's Avatar
Re: Head's Finally Showed up...
Nice...who is gonna port them? Whta type of flow numbers to expect? Also, what is needed for this conversion (probably setup for reverse cooling, but what intake and such)?
Old Jan 23, 2006 | 09:32 AM
Dennis at Airflow Development Will be doing them.. As far as the intake and stuff, it'll be a single plane efi setup, 4150tb and the rest is upto him..
Old Jan 23, 2006 | 09:53 AM
RealQuick's Avatar
Any particular valvertain needed or special pistons? This a 23 degree head right?
Old Jan 23, 2006 | 09:55 AM
Offset rocker's and lifter's, and std 23 deg. piston's are good to go.. yea it's a 23 well actually a 22deg. head.. 1 deg ain't nothing to brag about though lol...
Old Jan 23, 2006 | 10:41 AM
LT4POWR's Avatar
sounds like a good plan...next time make sure to leave the hairy legs outta the pics
Old Jan 23, 2006 | 12:21 PM
SStrokerAce's Avatar
Nice! Gotta like heads without pushrod pinch in them!
The valve spacing and rolled head might make a need for custom pistons or at least flycutting what you have.
Bret
Old Jan 23, 2006 | 12:55 PM
Bret
Well to be honest i'm hoping we can get by w/ just flycutting.. According to them i should be fine w/ what i have... We'll see..
Old Jan 23, 2006 | 07:09 PM
Mindgame's Avatar
I believe they're actually rolled over 2 degrees. Most 23 degree classes will allow a 2 degree roll over, that's why AP builds them that way.
Very good choice IMO!
Only advice I'd offer is to stay away from stud mount rockers. I don't care if they work or not. By the time you buy the good rockers, girdles and everything else you need, you could have had a set of shafts. JMO, having been there... done that.... but never again.
-Mindgame
Old Jan 23, 2006 | 07:45 PM
-Mindgame
Thanx... I'll be going w/ jesel's.. .. they're pricey though...
Old Jan 23, 2006 | 08:20 PM
Mindgame's Avatar
Jesel makes a good rocker setup and for stuff where I can get a valve cover with integral spring oilers, I've used them. I used them on my 383 with the MPD covers without an issue.
However, if you'd like to get away from plumbing oilers, then go with a T&D shaft setup with the optional spring oiler "holes" in the rocker. The circle track guys usually double their spring life with oilers and I'm a big proponent of them on any serious build. Cooler springs last longer and when cooler, they maintain more pressure as the revs get high.
Good luck Steve!
-Mindgame
Old Jan 23, 2006 | 08:24 PM
Plumbing a spring oiling sys. woudln't be that hard.. Would i just plumb from a oil supply source out of the block w/ a restrictor in line?
Old Jan 23, 2006 | 08:32 PM
FASTFATBOY's Avatar
Pops has a set of Crower solid roller lifters that are offset to work with your engine. We can also get a good price on a set of these:
http://dreracing.com/
Which is what we have.
Let us know.
BTW NICE HARDWARE!!
David
Old Jan 24, 2006 | 10:27 AM
The DRE stuff is nice as well... I do think the integral spring oilers are the way to go.
Bret
Old Jan 24, 2006 | 12:00 PM
i was checkin' that out.. look's pretty nice.. never heard of them. . but nothing wrong w/ picking out the color of myown rocker's..
