Heads and Cam Install
Old Jun 26, 2004 | 12:54 PM
blackz6sp's Avatar
My buddy just finished up heads and cam install, and car won't start, just cranks over. Any ideas? Can opti go in wrong, what hole does the pin go in? Any help would be great.
Shawn
Old Jun 26, 2004 | 12:57 PM
Mystic97Z's Avatar
ur supposed to do that actually to get the oil pressure up, we did that with mine by disconnecting the coil, so the car would crank but wouldn't start, check ur coil. just a guess?
Old Jun 26, 2004 | 01:03 PM
blackz6sp's Avatar
Coil is fine. Wondering which hole the cam pin is suposed to go in maybe??? square hole round hole?
Old Jun 26, 2004 | 01:19 PM
carlos64030's Avatar
Actually...the cam dowel should only fit into one hole on the back of the opti without any force whatsoever. When you bolted the opti to the front of the timing cover...there should not have been any resistance at all. The opti should have been flush against the timing cover before it was bolted down indicating that the cam dowel was seated in the proper hole.
Old Jun 26, 2004 | 01:24 PM
blackz6sp's Avatar
cool its coming apart now. I'm still guessing the square hole. I'm at work relay messages back to my buddy.
Old Jun 26, 2004 | 03:34 PM
blackz6sp's Avatar
It was the opti.
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
