Heads-Cam Idle Vacuum... experts inside
Old Sep 3, 2004 | 11:37 AM
Spinner's Avatar
Bought a VAC gauge, and it seems I'm getting around 10 inches of vacuum at hot idle (950). LE heads, 233/239 .570 lift cam, 112 ls. Is this normal? In the process of tracking down a LOT of missing power (Car ran 12.72@107 best with mods) Trying to rule out everything I can... and from what I've heard, this is pretty low. Experts give your opinions.
Old Sep 3, 2004 | 06:41 PM
slopokrodrigez's Avatar
Re: Heads-Cam Idle Vacuum... experts inside
Very low, maybe try a vacuum pump. Also, I could be wrong but the specs on the cam you are using seem to be for a blower.
Old Sep 3, 2004 | 08:42 PM
Spinner's Avatar
Its not a blower cam Just trying to figure out of this low vacuum is an indicator of a certain problem somewhere else.
Old Sep 3, 2004 | 09:26 PM
Dave C. '97 Z28's Avatar
I don't know if this will help, but my Hotcam and ported heads draws 14" of vacuum at 850rpm idle.
I would expect a cam like yours to draw less, so I wouldn't be surprised if it was pulling only 10".
However, someone with that setup should be able to give more light on what it should draw for you..
-Dave C. '97 Z28
Old Sep 3, 2004 | 09:36 PM
Fastbird93's Avatar
I've got a slightly bigger cam in my black car and am pulling about 9-10 at 800 Idle RPM and about 12-13 at 1050 Idle RPM at operating temp. Yes, I have two different tunes that have different idles set in them that I've run since yesterday, if anyone is wondering.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
KYWes
Jun 14, 2022 06:52 AM
big_mac421
Jul 13, 2015 03:48 PM
