heads/cam guys inside
Old Jun 11, 2006 | 07:01 PM
speed_demon24's Avatar
What spark plugs are you running? I'm just running the stock heat range autolite 106's, should I be running 1 step colder than stock, or the stock heat range?
Old Jun 11, 2006 | 08:26 PM
Slowmofo's Avatar
Re: heads/cam guys inside
NGK TR55's right now
Old Jun 11, 2006 | 10:04 PM
big dave's Avatar
TR55s here using the stock gap.
Old Jun 12, 2006 | 07:56 AM
96capricemgr's Avatar
If you want to stick with the Autolites go to a 104, otherwise as said the NGK TR55 is good, TR6 if you really pushed the compression up and drive in hot conditions might be a good idea.
Old Jun 12, 2006 | 08:03 AM
WhyHelloOfficer's Avatar
Running the TR55s now on my cammed car.. I'll be going with the TR6s when the kit goes on
Old Jun 12, 2006 | 10:31 AM
JustNO's Avatar
Its related to heads.. I know you can't use TR series for AFR heads for example.
Old Jun 12, 2006 | 01:09 PM
user 647483's Avatar
same
Old Jun 12, 2006 | 01:41 PM
CamaroBoy96Z28's Avatar
Originally Posted by James Montigny
same
Here too
Magenta_Hearts
Mar 25, 2015 10:24 AM
carl.froehlich
Mar 13, 2015 12:38 AM
squarehead
Nov 21, 2014 08:02 PM
F(ast)-body
Feb 26, 2003 09:05 AM
Red97LT1
Aug 7, 2002 05:45 PM
