Heads and cam complete!!!!!!!
Old May 13, 2004 | 10:00 PM
  #16
19camaro71's Avatar
if the tune, by the way I have heard Ion is one of the best, anyway
if the tune is for maximum power, the a/f mixture may be a little rich which would be why you are getting smoke.
again, it could be a number of things, sensors and so on.
Old May 13, 2004 | 10:04 PM
  #17
Hawk350's Avatar
so, where do I start? She I dino it and get it adjusted or what?
Old May 13, 2004 | 10:09 PM
  #18
19camaro71's Avatar
I am going to assume you aren't getting and codes, you could have it scanned, but I would simply say, have it dyno tuned, if thats available to you. Like I said, the tune may be off a hair, I could be wrong though. Once you have it dyno tuned, which is the best way to tune a setup like yours, and or get it scanned, post the results of it on here.
Once you get it dyno tuned, the smoke may go away.
Unless it cost you little to nothing to get it scanned, I wouldn't mess with doing it, I really don't think it wold turn anything up.
Get it dyno tuned, you could pick up some power and fix the problem.
Post your results!
Old May 13, 2004 | 10:13 PM
  #19
Hawk350's Avatar
first I am going to replace the wires, because its missing after running for a bit....then I will run her and see....I plan of getting the dyno tune as well.
Old May 14, 2004 | 06:35 PM
  #20
19camaro71's Avatar
sounds good-
post your results!
Old May 14, 2004 | 10:46 PM
  #21
Hawk350's Avatar
replaced the wires tonight, wen2t for a quick run, it was fine...tomorrow I am gonna drive some more and see what happens....3 of the wires I had were cut through the silicon coating....
Old May 15, 2004 | 09:09 PM
  #22
19camaro71's Avatar
so you just had a bad missfire then I quess,
still wouldn't hurt to strap it to a dyno and have it dyno tuned though
Beautiful car though!
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
