Heads/ cam....a bit confused.....
Old Feb 21, 2004 | 10:46 AM
Hawk350's Avatar
I am trying to decide what cam to go with. I am getting heads ported and bigger valves, springs, etc.....I see alot of posts for custom ground cams.....with my port job that I will be getting...what are the hp advantages of a custom cam? I was looking into the XE 230/236 but now I am reconsidering......if I can obtain more hp and torque with a custom cam, I would go that route. Can someone clarify this a bit more? TIA....
Old Feb 21, 2004 | 10:50 AM
SS MPSTR's Avatar
IMO, at this point in the game, you'd be foolish not to have your heads flowed and have a cam matched to the headflow and the use of the car. The additional cost is fairly insignificant, and the results much more predictable.
Just my $0.02. When I build my stroker, I plan to heed my own advice this time.
Old Feb 21, 2004 | 11:33 AM
Fastbird93's Avatar
A custom cam will be well matched to your heads, and power stands a good chance to completely overshadow any off the shelf grind. Plus, a competent cam designer will be able to give you what you want I.E. driveability, powerband, top end, more low end power, ect.
Joe Overton and Brett Baeur or something like that come to mind.
Old Feb 21, 2004 | 11:36 AM
Hawk350's Avatar
So the custom cam is best for a setup...correct? I guess the little extra $$ is well worth spent. I will talk to the guy that will port and see what he suggests.
Double aught
Oct 2, 2015 11:29 PM
greenzee28
Sep 25, 2015 04:29 PM
Greg88
Sep 20, 2015 07:14 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
