Heads and cam ???
Old Jan 7, 2010 | 07:14 PM
1slo93z's Avatar
Heads and cam ???
I have a 93 Lt1 Z28. I have a chance to buy a set of brand new Patriot 190cc heads complete, 2.02/1.60 valves, 5-angle valve job, and a Comp Cam 503.My question is....is Patriot a good brand and will the heads and cam get along. I also have a 3000 stall and a fully ported Lt1 intake with a 52mm T.B (not on car yet) One more thing I was planing on using 1.6 rockers would I have to change push rods....Thanks your helpful input would be appreciated
Old Jan 7, 2010 | 07:49 PM
Stl94LT1's Avatar
Changing rockers will have little or no effect on pushrod length, but changing heads and cam might. You should measure for correct pushrod length.
Old Jan 7, 2010 | 07:50 PM
96capricemgr's Avatar
I would not use those heads if FREE. Despite the name they are chinese junk. When a valve seat falls out BAD things happen.
Old Jan 8, 2010 | 11:15 AM
JAKEJR's Avatar
I question the quality of the aluminum used in their castings.
Jake
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
