Low coolant light
Low coolant light
Ok so i just changed the sensor because it came on and there was plenty of fluid in it. Now it is back on but only turns on sometimes when im at a red light or stopped. The car starts to heat up but if i turn it off and on the light goes off at first i thought a sticking thermostat but that is brand new then i thought maybe it could be the water pump but that is a month old. Anything else also my heater isn't really working very well when its really cold and the car doesn't heat up at all when it is cold idk what it could do
I think so i went checker and everything looked the same as the other one. But idk if it was specifically for ltx im just going to replace it see what happens
From Shoebox:
http://shbox.com/1/tstat.jpg
When you changed the sensor, you probably lost coolant. Did you replace the coolant, and bleed the air out?
Yeah i bleed it until there was no air at all i also checked the coolant level it and its full in the radiator and reservoir. The light doesn't come on immediately only if the car is warmed up and starts to creep up hotter then usual and once i start driving it cools down and the light stays on until i turn off the car and turn it back on. Ill try to bleed it again when i get home thanks for the input guys
Jan 23, 2015 01:13 PM
