Heads cam or 355?
Old Dec 18, 2005 | 06:35 PM
Jeremy95TA's Avatar
Heads cam or 355?
Well I was reading the other thread "355 v 383" and I was thinking, is there really a difference between a 350 and a 355? I know that when you build a 355 you are freshening the engine up, but when you bore it .30 over will those 5 cubes make a difference power wise? Essentially, isn't a 355 just a heads/cam car?
Old Dec 18, 2005 | 06:48 PM
FastZinTennessee's Avatar
Re: Heads cam or 355?
You can put heads/cam on your stock engine and you'll have a 350. If you rebuild your engine, bore it .030" over to clean up the bores you will have a 355, regardless of what kind of heads and cam you have.
5 Cubes really does not make a difference The other changes you make in a rebuild such as compression, heads, cam, etc can and do make a change.
Old Dec 18, 2005 | 06:58 PM
96capricemgr's Avatar
Yeah a 355 CAN be better than a stock bottom but the 5 extra cubes do little for that, compression and how you go about gettinf it are more important.
Old Dec 19, 2005 | 10:19 AM
jerrysta's Avatar
Heads are where you get your most power. If you have a really tired motor it might benefit from a clean-up that building a 355 would provide.
I'm not sure I would want to do heads/cam on a high mileage car when you might have to dig into the motor later anyway.
It's a catch 22.
mikey4play
Mar 15, 2015 11:45 AM
armedtrigger
Feb 24, 2015 08:30 PM
F(ast)-body
Feb 26, 2003 09:05 AM
Rich_z28
Aug 27, 2002 12:20 AM
