heads
Old Dec 9, 2003 | 11:13 AM
  #16
94formulabz's Avatar
Originally posted by cef97ws6
But to be honest I don't really put a lot of trust in just dyno numbers alone. I also like to see some track times to verify performance. More and more I see big variences with dyno numbers on similiarly modded cars which tells me dyno numbers can be inflated.
Nice combination you put together.
I agree to a point. dyno numbers are by no means the end all. But track numbers (mph and especially ET) can vary even more. Driver skill, tires/60', altitude, weather DA, weight, gearing. All those things can have large effects! IMO the dyno is a lot harder to manipulate. you also have to look at more than peak numbers as your head's low lift numbers (or flowbench method) demonstrate. There are probably a lot of guys on here that are saying "how'd he pull that much with an 'itty bitty cam' and only 25x peak flow? I'm typically not surpised much if at all when i see peoples dyno numbers, you have to expect some variance due to the cars condition and suttlties of the combination and its setup.
Bottom line, I like to see both dyno charts AND track times
-brent
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
