Headlight Adjustment, how high off the ground from how far away?
Old Nov 28, 2003 | 08:24 PM
BOWTYDE's Avatar
Isn't is a 2" drop 25' feet away?
Old Nov 28, 2003 | 10:18 PM
Joe Bellman's Avatar
This is from my Haynes manual:
Park car 25 feet away from wall on level surface, half tank of gas and no loads in the back end.
Put tape on wall vertically. Line it up with the center line of the car. Use two more vertical pieces of tape and line them up with the headlights.
Put tape horizontal on wall at same distance from the ground as the headlights. Maybe easier to do with the car a few inches away from wall.
Low Beam: Brightest part of light beam 2 inches below horizontal tape line and 2 inches to the right of the headlights vertical line.
High Beam: Brightest part of light beam zone should be vertically centered with the exact center just below the horizontal line..
This is will just get you close. For the best results you should fine a dark back road to get the adjustment down right. Make sure you don't get them too high or you will be hazard to on coming cars. Personally, I like my high beams a little on the high side and spread out. Most the roads around here are curvy and have many hills.
Z28Freak86
Apr 28, 2015 10:35 PM
ChrisFrez
Feb 15, 2015 08:12 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Dec 4, 2014 11:56 AM
