headers were glowing red last night
When you do the header swap, you're practically taking off the Cat anyways. If you can look through the honeycomb, you're probably fine. In Cali, I would recommend the MAC Off-Road Pipe with fasteners for quick removal. That way, you can drive "to the track" and swap in the Cat at any time.
http://www.speedconcepts.net/late_mo...ers_Ypipes.htm
I know a fabricator who can fix it up for you...
But if you're glowing red, it is likely from over-scavenging in the exhaust or ignition not firing the mixture.
Yep, the TES should come with a y-pipe. If you scroll down on that link, you'll notice an Off Road Pipe (used in place of the cat). That way you don't have to bash the cat out (gutting). You can put it on and off whenever you please.
Technically yes. Officially, any tampering with emissions equipment could be trouble.
Victor Lamb
Aug 26, 2017 02:52 PM
