Header Temp
Old Mar 2, 2006 | 12:44 PM
  #16
Dfetter84's Avatar
Re: Header Temp
ok called the computer guy
0 = BLMS
Stock = Cylinder Balance Table
Old Mar 3, 2006 | 08:10 AM
  #17
Dfetter84's Avatar
Re: Header Temp
Checked the harness with the NOID lights
all worked but the light seemed a little week
Old Mar 5, 2006 | 02:59 PM
  #18
Dfetter84's Avatar
Re: Header Temp
anyone think this is a stuck injector
Old Mar 8, 2006 | 10:07 AM
  #19
Dfetter84's Avatar
Re: Header Temp
all injector harnesses have steady 11.75 volts with key on
Old Mar 8, 2006 | 11:15 AM
  #20
evilundisguised's Avatar
Re: Header Temp
One stuck injector wouldn't affect 4 cylinders, and it's pretty improbable to have 4 stuck injectors all on the same bank.
Old Mar 8, 2006 | 02:38 PM
  #21
Dfetter84's Avatar
Re: Header Temp
i would say ignition but the coils are working.
i am getting fire to the plugs i have an inline tester
Old Mar 10, 2006 | 08:23 PM
  #22
Dfetter84's Avatar
Re: Header Temp
swapped o2's
same readings
also noticed that the car revs it self up freely when holding accelerator
2000 to 1500 to 2000
thought it was my error but its not
Old Mar 10, 2006 | 08:52 PM
  #23
turbo_Z's Avatar
Re: Header Temp
Maybe you have a head gasket leak? I dont see how even running extremely rich would make a 300 degree difference in header temp.
Old Mar 10, 2006 | 10:47 PM
  #24
96camaroSS's Avatar
Re: Header Temp
I assume you have ceramic coated headers right? Infrared temp sensors don't read accurately at all when used on a reflective surface.
Old Mar 11, 2006 | 02:07 PM
  #25
Dfetter84's Avatar
Re: Header Temp
compression test shows 202psi on each cylinder
yes i have ceramic coated headers but i still disagree with you
why would my car make only 270rwhp on the dyno unless i was missing a few cylinders
Old Mar 11, 2006 | 03:05 PM
  #26
96camaroSS's Avatar
Re: Header Temp
I'm not saying you are or are not dropping any cylinders. I AM saying you cannot trust infrared temp guns on reflective surfaces. They will not give you anything close to an accurate reading on a reflective surface.
Old Mar 11, 2006 | 11:25 PM
  #27
tritonium's Avatar
Re: Header Temp
Ill be the jerk
Optispark
Old Mar 13, 2006 | 12:44 PM
  #28
Dfetter84's Avatar
Re: Header Temp
see sig
Old Mar 13, 2006 | 06:17 PM
  #29
tritonium's Avatar
Re: Header Temp
see sig
Delteq still uses the opti to a certain extent. when was the last opti replaced?
Old Mar 14, 2006 | 09:46 AM
  #30
Dfetter84's Avatar
Re: Header Temp
100 miles ago
