Header Temp
Re: Header Temp
Best way is to do it like you are reading plugs.
Run it hard, and then kill it immediatly and take the readings. You also want to make sure you take the readings at the same spot on all primaries.
Re: Header Temp
Originally Posted by J Rod
Sure you can. Just remove your hood and driver's side t-top, throw a brick on the gas pedal, and lean over the windshield with your temp guage.
Reading your sig you have changed the engine much from stock. What are the cyl balance tables sitting at? Datalogging? what about the blms?
