Header rubbing steering shaft....
Old Dec 2, 2005 | 08:17 AM
  #16
Black_95Formula's Avatar
Re: Header rubbing steering shaft....
I have the same problem. Actually, after rebuilding the engine and throwing in a pair of poly motor mounts, the column was rubbing on my header during turns. Not sure what I am going to do.
I have the rag joint eliminator from Unbalanced Engineering ($35) which is a nice piece. So I don't want an LS1 steering column.
Old Dec 2, 2005 | 09:18 AM
  #17
chrisn's Avatar
let us know how that rag joint eliminator works out. i might look into one.
Old Dec 2, 2005 | 09:34 AM
  #18
Oh, I had the rag joint eliminator for over a year. It fixed most of the play issue. I highly recommend it, especially for cars with headers that melt the stock rubber and fiberglass rag joint. The rest of it was fixed by ordering a good set of Moog inner and outer tie rods.
Old Dec 2, 2005 | 11:27 AM
  #19
chrisn's Avatar
good stuff, do you have a quick link as to where to get one?
Old Dec 2, 2005 | 11:28 AM
  #20
chrisn's Avatar
n/m i got it
Old Dec 2, 2005 | 09:09 PM
  #21
lr383's Avatar
I also have rk sports headers . I had to put a small roll in mine to help with clearance. rk quality is not consistent. My son also as rk, his is almost a half a inch difference in location. main I problem is the tube is to close to the heat shielding.
Old Dec 11, 2005 | 04:58 PM
  #22
wrd1972's Avatar
Here is the picture of my modded steering shaft. I legthened it 3/4" and welded it up and shifted the steering column.
The header primary no longer comes close to banging it.
Here is before:
http://www.MyOnlineImages.com/Member.../DSCF00141.jpg
Here is after:
http://www.MyOnlineImages.com/Member...s/DSCF0035.JPG
You can tell from the photos that the steering shaft is straighter wich is always better for the u-joints anyway.
Old Dec 11, 2005 | 05:03 PM
  #23
wrd1972's Avatar
I ended up removing that sheet metal shield and bent the rear brake line down and well out of the way of the header.
The RK sport headers definitely have fitment issues that require creativity and patience.
Mine now fit flawlessly and were worth $490.00 shipped and nearly 24 hours of install time.
Old Dec 11, 2005 | 09:33 PM
  #24
mkent's Avatar
it's a simple fix. just cut the steering shaft out with a torch! who needs that thing anyways?
someone already mentioned the shaft is adjustable. I think you have to remove the plastic dust shield in order to get to the steering knuckle bolts. Also, motor mounts may help too but I got away with adjusting the shaft and leaving my original motor mounts in.
edit: I should have read the last post where you solved your problem. Nice work.
Old Sep 16, 2006 | 03:17 PM
  #25
Bandit95LT1's Avatar
does anybody know if the the ls1 sterring shaft will work with all header or is it only for rk sports? i have pacesetter mid length and they are rubbung a liittle bit.
Old Sep 19, 2006 | 08:08 PM
  #26
wrd1972's Avatar
Yes the LS1 shaft will work, but thteering wheel will be very off center and require an alignment if you want it to be straight.
Victor Lamb
Aug 26, 2017 02:52 PM
CheckOutMyRoost
May 23, 2015 02:33 PM
jackpawt883
May 20, 2015 06:53 AM
CaRParts102
Dec 6, 2014 08:45 AM
