header question
Old Nov 20, 2004 | 08:54 PM
350TPI5SPEED's Avatar
header question
what are the differance in headers for lt1 cars? is it the y-pipe or egr? my brother has a 97 ta and he found a good deal on earlier set. will they work or not?
Old Nov 21, 2004 | 09:53 AM
Re: header question
The 96/97 cars are "dual cat" and have the drivers side cat up against the stock exhaust manifold. A true "dual cat" (96/97 sepcific) header will have the same configuration, making it a completely different shape than a single cat header. That also changes the Y-pipe shape.
The 96/97's have the same EGR connection as all the other years (except 93). The AIR connections are similar, but a smaller diameter, requiring a different fitting than the 93-95 headers.
If you put 94/95 headers on a dual cat 96/97, you need to use the Y-pipe that comes with the 94/95 headers, and possibly an "S" pipe to get the Y-pipe to connect to the stock catback.
Old Nov 21, 2004 | 10:48 AM
Re: header question
the y-pipe is "off road" so there would be no issue with the cats. so....an air fitting and an s-pipe and they would work?
Old Nov 21, 2004 | 08:01 PM
Re: header question
You would need an adapter for each of the AIR fittings, and the S-pipe.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
