Header problems?
Old Jun 15, 2009 | 07:45 PM
TM2S3's Avatar
Header problems?
I just had long tube hooker headers put into my 93 z28 and I'm having a couple of issues. When I picked it up today the mechanic told me that I needed a new transmission mount, which I definitely could tell when I was driving home, it was knocking real bad. So I changed the mount, and now its driving a little better. But now I hear a loud pinging sound under my feet when I drive in reverse. Another thing is that when ever I turned right it felt like something was sticking. So I looked under the hood and I could see the steering joint rubbing against the headers. I was wondering if this was bad or if I shouldn't worry about it.
Old Jun 15, 2009 | 08:48 PM
Black396's Avatar
The steering shaft hitting the headers is a problem. Same thing happend to me on my car after i put poly engine mounts in. Just take a hammer and punch or drift and peen over the thin steel bracket that goes around it. Clearance it then put the car in the air and turn the wheel back an forth and make any nessary modification to make it clear. Has no effect on the shaft. Thats modding cars. Sometimes **** just doesnt fit
Old Jun 15, 2009 | 09:26 PM
TM2S3's Avatar
Thanks, Ill give it a try.
I was just thinking. The o2 sensor on the passenger side was to short, so it is currently disconnected. Is there any chance that this is causing the knocking sound on the drivers side?
Old Jun 15, 2009 | 10:41 PM
Disconnecting the O2 sensor keeps the ECM from entering closed loop. You need to hook it up so the ECM can control the A/F ratio correctly. It isn't going to cause anything to rattle or knock on the driver's side though.
Have you inspected the headers to make sure they aren't hitting the subframe or the floorboards on the driver's side?
Old Jun 15, 2009 | 10:58 PM
TM2S3's Avatar
I haven't checked that very thoroughly, but if that was the problem would it be a lot worse in reverse than it is in drive?
Old Jun 15, 2009 | 11:13 PM
Yes, it could be. The engine moves around (twists on the motor mounts), in response to the torque on the drive shaft. When the tranny is in reverse, the engine torques in the opposite direction than it moves when you are moving forward. May indicate weak motor mounts.
Old Jun 15, 2009 | 11:21 PM
TM2S3's Avatar
I didn't realize that. Ill check that out tomorrow. Thanks
Old Jun 16, 2009 | 06:25 PM
TM2S3's Avatar
You were right. I had the problem fixed today.
Old Jun 16, 2009 | 07:31 PM
Thanks for the feedback.
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
