Header install in progress, broke something (did search)
Old Apr 19, 2005 | 05:28 PM
lookingforwheels's Avatar
Hello,
I'm in the process of installing headers on to my car, and on the drivers side when I removed the manifold I broke some white sensor thing. It seems like it screws right into the motor and has an electrical fitting. Does anybody know what this is?
Old Apr 19, 2005 | 05:38 PM
chevyguy3's Avatar
Re: Header install in progress, broke something (did search)
sounds like the coolant temp sensor. located in the clyinder head, between the first and 2nd cylinder on the driver's side. has 1 wire going to it
if that is what you broke, dont worry about it. they are usually in stock at just about any auto parts store and dont cost much
Old Apr 19, 2005 | 05:39 PM
Dave89IROC's Avatar
sounds like the coolant sender foir the gauge
Old Apr 19, 2005 | 05:51 PM
Cool thanks for the replys, I was worrired it would be something wierd that nobody has heard of, one last thing, when I pull it out will coollant flow out? Should I drain my radiator first?
thanks for the help!
Old Apr 19, 2005 | 05:54 PM
Dave89IROC's Avatar
coolant will come out, if you get the new one first, just change it quick
Old Apr 19, 2005 | 05:56 PM
chevyguy3's Avatar
yeah, quite a bit of coolant will come out, even after you drain the radiator. if you want to avoid making a mess, you will have to drain the block/head from the plug under/behind the drivers side motor mount after draining the radiator
IMO its easier to just pull and change the sensor without draining the system and just let it make a mess
Old Apr 19, 2005 | 06:24 PM
ajschult's Avatar
you try to jack up the driver side of the car right before you change it. That might help with spilling, not going to be as easy to reach though.
Old Apr 20, 2005 | 07:38 AM
1-bad-z28's Avatar
somebody else did the same thing about a week ago. It was the exact same question with the same answers. I kept looking at the date thinking this can't be right. Anyways, hook up a funnel to a piece of tube that runs to your drain pan you put under your car. Pull the sensor out and let it drain. Then put the new one in.
Old Apr 20, 2005 | 07:56 AM
BRIAN93Z28's Avatar
If it plugs into the block, bout halfway down you may have busted the oil pressure sending unit. VERY common with header installs, broke mine when i did my headers on my LT1. Luckily they are fairly inexpensive, shoudlnt cost you more than about $20 bux at an auto parts store. Surprised no one mentioned the sending unit.
Brian
Old Apr 20, 2005 | 08:51 AM
1-bad-z28's Avatar
the oil pressure sending unit is only on the side of the block in 93. In 94 and up it is right behind the intake manifold. He didn't mention what year car he has.
Old Apr 20, 2005 | 11:19 AM
MarkyMark's Avatar
That was me . I still havent replaced mine, gonna go to the dealer and pick up a few things today and install it on Saturday. Should be a piece of cake.
Old Apr 20, 2005 | 12:04 PM
BRIAN93Z28's Avatar
AAAAAAAAAAAAHHH....I did NOT know that. Thanks for the info!
dmcdonald96
Jan 30, 2015 06:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Dec 1, 2014 08:08 AM
1LEThumper
Jul 14, 2003 12:45 PM
