Header Install +?
Old Jun 16, 2004 | 03:03 PM
transamdude95's Avatar
Header Install +?
I might actually be getting headers soon and having them installed. I was just wondering what else should be done(or would be easier to do) while doing the headers? I haven't had a tune-up yet(66k miles) so I figure that should be done. Anything else?
Old Jun 16, 2004 | 03:22 PM
BUBBA's Avatar
If you are supplying the headers, make sure you have EVERYTHING you need for the install, including gaskets, bolts, fire sleeves (if needed) etc.
If you don't the shop may just grab whatever is handy and you won;t be happy.
And before you go runnin' around make sure the primaries are clear of all wiring and hoses.
Shops tend to ignore these details, but if you burn a wire or hose, you will wind up with another problem (s) JMHO
Old Jun 16, 2004 | 03:59 PM
LWillmann's Avatar
You might want to consider motor mounts. Much easier without headers in the car.
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
