Header install
Old Feb 18, 2004 | 03:27 PM
19formula94's Avatar
Header install
Doing the header install on Monday, just wondering if there's any last minute tips or advice for installing the Jet-Hots to make it easier on me. Thanks for any input
Old Feb 18, 2004 | 03:38 PM
Scream And Fly's Avatar
Have friends on standby, ready to bring Taco Bell...
Old Feb 18, 2004 | 03:44 PM
OffspringZ28's Avatar
take your time. be prepared to lift the motor a little (not hard). and dont let yourself get bothered too easily, it is trying on your patience. also, might as well replace plugs wires etc, and above all, take lots of pics and try to have fun.
Old Feb 18, 2004 | 04:02 PM
z28marine's Avatar
Take your time, and dont become frustrated...you might think a certain part is impossible but there are a ton of people who have done exactly what your doing and have been stuck too...you can pull through. Try taking a break somewhere in there get some good and rest. I noticed as i was finishing up i tended to want to get done alot faster which meant cutting corners and later having to go back and correcting the problem which made it alot hard on me....good luck...its a great time!
Old Feb 18, 2004 | 04:22 PM
Red96Lt1's Avatar
Have the beer and bandaids ready!!!!
Old Feb 18, 2004 | 04:25 PM
WS Sick's Avatar
Also lift the car as high as you can so you can do alot of finangling. The pass side header is the bugger.
Old Feb 18, 2004 | 04:37 PM
SlickBlack Z's Avatar
Have some zip-ties on hand. You will need them to hold wires away from the headers. This thing came in very useful as well:
http://www.slponline.com/view_produc...RTNUMBER=30102
Old Feb 18, 2004 | 10:43 PM
thanks for the input, i plan on taking lots of pics. Also doin the plugs and wires. Figured i'd put in a 160 thermostat too, is there much to do for that? I'm working with a guy thats done this before so it should go fairly well
Old Feb 18, 2004 | 11:30 PM
speed76demon's Avatar
Thermostat is a piece of cake. However long you think it will take double it haha. Hard to get the oil tube back in with the head install. Also do you have ovc wires if so might want to get the heat sleeves I didn't and my wires are arcin and needs to be fixed
Old Feb 18, 2004 | 11:34 PM
Here's a little trick i'll share about the dipstick. Since it always leaks after removal as everyone says, I chose to cut mine near the base with a dremel tool and slip fit it back together with a length of rubber hose after the install. No leaks...and takes some 'headache' out of the header install.
Old Feb 18, 2004 | 11:39 PM
pntballty's Avatar
19formula94, i will be doing mine in about a week and a half, trying to make sure i have everything also. Anyone have a checklist they can post Thx Tyler
Old Feb 19, 2004 | 04:28 AM
jeremyferguson's Avatar
I've got about 19 hours into my install. All I have left to do is the OVC taylor wires and put the alternator back on. Everything else is done. Since I had to lift the motor anyways, I removed the frame and motor mounts and sandblasted them and painted them with engine paint(red). Also got red poly motor mounts. There a lot more visible with headers instead of manifolds. I took my time and put 2-3 hours in at a time, but it was extremely frustrating at times. Heres the stuff I can think of off the top of my head that I used for my install:
Felpro 1406 gaskets.
ARP polished stainless header bolts.
o2 extensions(I soldered my own).
Taylor OVC wire kit.
NGK TR6 plugs(nitrous).
Energy suspension Poly motor mounts.
Tie Wraps(already had them).
I'll probably think of more as soon as I submit this...
Old Feb 19, 2004 | 08:57 AM
yea i got the ovc kit and the 1200 fire sleeves. i'll have to pick up some twist ties. Chose not to go with new motor mounts, hopefully that doesnt bite me in the butt
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
