Header Install
Old Dec 18, 2003 | 02:27 PM
smokerZ28's Avatar
Header Install
I have been reading various write-ups on header installs, learning as much as I can before I try my install. All of the write-ups I have found retain the emissions. Does anyone have a link to one without the emissions? Im going to delete my emissions and would like to study it. Thanks in advance.
Old Dec 18, 2003 | 03:32 PM
ibanez6rg's Avatar
Well if you're not doing it with emissions, all you have to do is take the emissions off.
AIR pump and EGR. And get some block off plates for the back of the intake.
AIR pump will come off in less then 10 minutes. It was a pita removing the bolt on the manifold for me, for the EGR pipe.
Old Dec 18, 2003 | 03:37 PM
LWillmann's Avatar
TheHeadFL recently did a header install, with an EXCELLENT write up with pics... I believe that he removed his emissions stuff... Just seatch for his posts and you should find it..
Old Dec 18, 2003 | 06:11 PM
94TA_LT1's Avatar
I will sell you some block off plates if you are intersted
Old Dec 18, 2003 | 08:17 PM
ibanez6rg's Avatar
Block off plates.
Old Dec 18, 2003 | 08:28 PM
AsianSensation's Avatar
Or make some on your own.
EGR blockoff plates dimensions
Pics of home made EGR blockoff plates
Old Dec 18, 2003 | 09:38 PM
suprchrged400's Avatar
don't forget you must program out (delete) the polution controls you are removing or it will throw check engine codes. Just a friendly reminder
Old Dec 18, 2003 | 09:42 PM
ibanez6rg's Avatar
Shouldn't throw any SES lights, it's a 94.
Old Dec 18, 2003 | 10:40 PM
smokerZ28's Avatar
Thanks for all the info guys, I am gonna get a PCM4less tune, so I will have the emissions deleted.
Old Dec 18, 2003 | 11:05 PM
revtime's Avatar
I deleted my emissions when I installed my LTs and never got a SES light.
Old Dec 19, 2003 | 06:56 AM
IslandZ's Avatar
Okay Idid header two weeks ago, but I only blocked the EGR itself and the tube the went into the manifold.
Where does the oval shaped plate with the 1 hole in it go???
Help please I may need to block that one still!
Old Dec 19, 2003 | 07:31 AM
ibanez6rg's Avatar
2 of the plates go in the back of the intake and if you got headers with emissions, 1 goes on the header (in the back).
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
