header help
Old Feb 14, 2006 | 10:13 AM
green zr1's Avatar
header help
what are the advanges of running long tubes vs short tube headers. id like to compare them price wise and ease of install
Old Feb 14, 2006 | 11:05 AM
2000GTP's Avatar
Re: header help
Ease of install and pricewise they are probably pretty close to each other. The main issue is if you have emissions to deal with. If so, then shorties or mid-lengths would be more suitable. If not, then long tubes are definitely a good way to go as they should add some additional power over shorties and provide better plug access.
Old Feb 14, 2006 | 11:15 AM
teke184's Avatar
Re: header help
long tubes give significantly more power gains than shorties. this becomes even more evident as hp levels get higher.
shorties are only good for about 5-10hp depending on whether you replace the ypipe or not. LTs are good for a solid 15-20hp.
Old Feb 15, 2006 | 07:51 AM
green zr1's Avatar
Re: header help
are you saying the long tubes are not legal why
Old Feb 15, 2006 | 08:02 AM
Re: header help
Not legal because they move the cat(s) from the stock location.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
