Header gaskets.. Percy's or Earl's?
Old Oct 23, 2003 | 01:01 PM
madwolf's Avatar
Arrow Header gaskets.. Percy's or Earl's?
Which ones are better? If Percy's, I need the square port ones, right?
Thanks!
Old Oct 23, 2003 | 01:11 PM
BradZ28's Avatar
I used Percys "dead soft" gaskets once and they worked great. I beleive they are still D port, but a little costly. They flatten 3 or 4 thin sheets of aluminum to form very well.
http://www.jegs.com/cgi-bin/ncommerc...49&prmenbr=361
Brad
Old Oct 23, 2003 | 01:15 PM
madwolf's Avatar
I knew about the D-port, but summit doesn't have those (they do have Earl's D-port however) so I figured the closest to D would be the square ones they carry but I guess not.
Thanks Brad.
Z95m6's Avatar
i have percy's and i believe you need D-ports if i remember right. Make sure you have 1 inch bolts though, because the gaskets are super thick. I only had 3/4" bolts and i could barely get them started and i had to jump around tightening them up so i wouldn't strip them out.
Old Oct 23, 2003 | 01:21 PM
FacelessZ's Avatar
As far as Percy's ''Dead Soft'' Header Gaskets, do we get round or square?
Thanks!
Old Oct 23, 2003 | 01:23 PM
BradZ28's Avatar
760-66031 SB-Chevy D-PORT LT1
Click link above......
Brad
Old Oct 23, 2003 | 01:30 PM
turbo_Z's Avatar
Jegs has the Percy's listed on their site for LT1 D-ports... about $30 if i remember correctly.
edit: everyone beat me to it
Old Oct 23, 2003 | 03:21 PM
97FormulaWS-6's Avatar
I've got a set of Earls aluminum ones with the inserts that are about $5 from summit.
I have yet to install them but....
I am VERY impressed with them from just inspecting them. From an engineer's standpoint that's how header gaskets should be made. Not to mention if you've ever heard of Parker-Hannifin they made these gaskets for Earls... and they ARE the seal company...
They'll get tried out next spring... car's going in storage in 3 days.. and the heads are getting a P&P job this winter...
Old Oct 23, 2003 | 03:30 PM
DB75's Avatar
Get the Percy's (square) and 3/4 in. Stage 8s. You won't be dissappointed.
Old Oct 23, 2003 | 03:36 PM
mongse_1's Avatar
I'm ran Earl's Pressure Masters with my supercharger and will run them again w/ the turbo. Best header gaskets I ever bought...not one leak.
Best thing is all I had to do to switch from the LT1 d-ports to my current square ports is switch inserts. Nice and easy.
Old Oct 23, 2003 | 04:46 PM
BUBBA's Avatar
FELPRO
Old Oct 23, 2003 | 07:51 PM
Bud M's Avatar
Earl's are working great for me too.
Old Oct 23, 2003 | 08:20 PM
madwolf's Avatar
Thanks guys. I went ahead and bought Percy's gaskets along with some poly motor mounts from Jeg's.
Old Oct 23, 2003 | 08:25 PM
drewstealth's Avatar
I was gonna use some Felpro gaskets when i do my header install. Is there a reason the percy's or earl's are better?
Old Oct 24, 2003 | 06:56 AM
DB75's Avatar
The Felpros will eventually succumb to the heat. You can't beat Percy's or Earl's gaskets. Aluminum is the way to go.
