Header gaskets.. Percy's or Earl's?
Old Nov 12, 2003 | 08:14 AM
  #16
viper3885's Avatar
i have a question. if my header flange is slightly warped, will the aluminum one bend to the shape and make a leakless seal? i'm not sure if they're actually warped or not, i'm asking b/c i had paper gaskets on my headers and they were fine until they blew, then i bought mr. gaskets copper seal gaskets. but the copper ones leak. if i got percy's or earl's aluminum gaskets would it be leakless? thanks in advance.
Old Nov 12, 2003 | 09:13 AM
  #17
bradpreece95z28's Avatar
I have had Percys on my car for two years
Get this, I have re used them three times and STILL no leaks...well spent money if you ask me.
Old Nov 12, 2003 | 09:35 AM
  #18
Bud M's Avatar
If they are warped you would need a compessible gasket to seal, not a metal one. But you would be better off removing them and checking to see if the are actually warped, and if they are, getting the flange resurfaced.
Old Nov 12, 2003 | 10:15 AM
  #19
viper3885's Avatar
how can i tell if it's warped? would i be able to just look at it and tell. b/c if that's the case it doesn't look like it's bent or wapred or anything. maybe the copper gasket just isn't thick enough, right now i'm using 1 inch bolts on the header with a locking washer on each one. if the aluminum gasket is thicker then i shouldn't have a leaking problem. but i'm not too sure.
Old Nov 12, 2003 | 10:36 AM
  #20
Mike383LT1's Avatar
header gaskets
i used the flowtech same as a perceys they are nice only draw back is on a ported head they will cover some of the port this hurts performance i went to a felpro 1406 held up fine with forced induction
Old Nov 12, 2003 | 10:43 AM
  #21
drewstealth's Avatar
I'm a little confused. So with the Percy's do you get D-ports or the square ports on the stock heads? Then if you get them ported which do you use?
Old Nov 12, 2003 | 10:45 AM
  #22
viper3885's Avatar
you get the d-ports on stock heads.
Old Nov 12, 2003 | 11:09 AM
  #23
madwolf's Avatar
I ended up gettings some Percy's gaskets. Very nice!
I'll start the car before the weekend and let you know how they perform.
Old Nov 12, 2003 | 11:22 AM
  #24
Okay thanks.
Old Nov 12, 2003 | 08:44 PM
  #25
Bud M's Avatar
If you have them off the car, lay the flange on a piece of glass. If any part of the flange is not touching the glass they are not flat. You can check it with a feeler guage.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
