Header gaskets
Old Feb 19, 2004 | 04:28 PM
  #16
stereomandan's Avatar
Originally posted by 96ta(nick)
[B]there is an extra set of holes in the heads... [/B
?from what?
Dan
Old Feb 19, 2004 | 05:12 PM
  #17
CoUnTryMuZiCZ28's Avatar
There are two sets in the front and back.. I have no clue why...
Old Feb 27, 2004 | 08:59 AM
  #18
rickyzZ28's Avatar
I am having this problem myself. I had the percys gaskets and they always leaked, so Now I went and bought GM gaskets and the holes are in the outside of the gasket and they are riveted together right where the hole for the header is. My percys also had this but it was to help hold the gasket up to the head.
Old Feb 27, 2004 | 09:28 AM
  #19
ibanez6rg's Avatar
Fel-Pro's
The extra holes are probably for the Vette manifolds.
Old Feb 27, 2004 | 10:25 AM
  #20
30thannZ28's Avatar
On my old set of headers (MAC shorties) I had both the embossed earl's gaskets and the copper gaskets and stage 8 locking bolts and BOTH sets of those gaskets leaked like crazy. I ended up going with the fel pros before I switched headers. hope this helps, just my $0.02
Old Feb 27, 2004 | 11:19 AM
  #21
CamaroBoy96Z28's Avatar
Originally posted by stereomandan
?from what?
Dan
The extra outermost holes in the heads are what the headers use to bolt on. The inside ones are where the stock manifolds bolt on because they're a tad bit shorter in width across the head.
Old Feb 27, 2004 | 01:36 PM
  #22
drewstealth's Avatar
I'm have the percy's dead soft gaskets. I am gonna use them for my header install in a few weeks. Which side goes on the head the flat or the rivited side?
Old Feb 27, 2004 | 01:40 PM
  #23
The side with the part numbers face the headers.. or anynumbers..
Old Mar 1, 2004 | 11:49 AM
  #24
k thx
Old Mar 1, 2004 | 12:10 PM
  #25
Red96Lt1's Avatar
Copper here and no problems.
Old Mar 12, 2004 | 03:06 PM
  #26
z28marine's Avatar
copper suck! put them on...leaked like a mo fo...put on some generic kind that are aluminum on the outside and composite stuff around the exaust holes....no leaks, and one header bolt isnt even in!
Old Mar 12, 2004 | 11:01 PM
  #27
JJ's95B4C's Avatar
Sorry, but i have to correct you on this...the inner holes, closest to the exhaust port are the ones that the headers go into. The outer holes are the ones for the stock exhaust manifolds.
As for the GM gaskets missing the inner holes, I helped a friend do an install on LT's with those exact gaskets, and we ended up mocking up the headers as if we were going to install them, and marking the hole, then drilling a new hole through the gasket. This won't disrup anything because they are the crush ring gaskets.
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
