Header Gasket???
Old May 15, 2006 | 08:59 PM
LagunaS3's Avatar
Header Gasket???
I'm wondering what header gasket I need for my headers? I have what are supposedly SLP Long-tube headers...but they are made very similar to Hooker's. I already tried to use the factory exhaust gaskets, and they just don't cover the ports...any ideas? I've heard Fel-Pro 1406...do they fit well?
Zach
Old May 16, 2006 | 12:14 AM
sssalah's Avatar
Re: Header Gasket???
Can't go wrong with the felpro 1406.
Old May 16, 2006 | 12:40 AM
hotrod18_69's Avatar
I'll secound that!
Old May 16, 2006 | 02:43 AM
Joe B's Avatar
Yea the 1406's are usually a good fit.....unless your heads have had the exhaust ports raised at all....like mine were.....so I had to dremel them out a bit on the top of the gaskets ports......once you get the header gasket matching the heads exactly, then bolt them (the header gaskets) against your headers, and port the header flange to match the head port "exactly"......this is always worth checking with any head, header, and header gasket combo......(even on stock head exhaust ports, as far as the way they match the header ports).........
Old May 16, 2006 | 05:05 AM
LagunaS3's Avatar
Ok, so now it's time to start hunting 1406's locally. I just know the stocker doesn't fit the header at all!
Thanks,
Zach
Old May 17, 2006 | 05:12 AM
LagunaS3's Avatar
Wound up going with a Fel Pro 1426...the 1406 just didn't seem to fit quite right. Thanks!
Zach
Old May 17, 2006 | 06:39 AM
LameRandomName's Avatar
The brand and composition of the gasket doesn't matter.
The installation procedure does.
You CANNOT just install it and forget it.
I bought the headers that are on my car I think... three years ago...?
It was the kind that looks like compressed cardboard. I installed it, fired the engine and shut it off 5 minutes later. I retightened the bolts and ran the car for 10 minutes and shut it off again, retighteneing the bolts again.
I then carried a small box wrench with me for a few days and every time I wanted to start the car I would tighten the bolts first.
I think I did this three times before I stopped finding loose bolts. When I failed to find loose bolts three times in a row, I was done.
Gaskets haven't leaked yet.
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
